Top stopped working, top and rear windows won't work. Fuse ok, any suggestions?
Submitted by bailey.ac@gmail.com on Sat, 08/16/2014 - 09:38
Submitted by stevejag@sbcgl… on Fri, 08/15/2014 - 19:26
'04 XJS Convertable top
Yes, there is a microswitch on the handbrake lever. When the lever is pulled, it lights the telltale on the instruments and enables the convertible top. No telltale, no top operation; unless the bulb is burned out.
Good luck!
Submitted by bailey.ac@gmail.com on Fri, 08/15/2014 - 13:29
Switched switches, as suggested, no luck. Is there a switch on the hand break that can be checked or disabled?
Submitted by stevejag@sbcgl… on Fri, 08/15/2014 - 13:03
Does the 'Park Brake' telltail come on when you pull the brake lever up?? If it does not, the top won't work.
Submitted by bailey.ac@gmail.com on Fri, 08/15/2014 - 11:50
Thanks, I'll see if I can get the switches out without breaking the bezel. The fuse is good
Submitted by merkles@comcast.net on Thu, 08/14/2014 - 15:44
Did you check the 30amp fuse in the trunk above battery?
It may be the actual roof switch. I had to clean my switch contacts on my 1995 XJS 2+2. You could easily test the switch by removing all three switches: left window switch, roof switch, right windows switch. The wiring connections are the same so you could swap one of the windows switches with the roof switch for a test. If the swapped switch works the roof, then it is the switch. You can open these switches witch a small screwdriver and clean the contacts, otherwise, you could just replace the switch.
If the switch is not the issue, there are relays in the trunk above the battery and a 30amp fuse
The light on the instrument panel lights up. Does that mean the hand break switch controlling the top is working properly?
