Hello all. I have a 85 XJ6 and i live in Henderson Nevada where the temps now are 105. Last month the car is acting like it's staving for gas. I've checked several things and it's mind bogeling.
I just heard today from someone that 1983-1987 have problems in high heat due to how the gas line runs.????
Please Help.
Thanks Marco
Submitted by davalanbrow@att.net on Wed, 05/23/2012 - 18:03
Submitted by acrcllc@gmail.com on Mon, 09/05/2011 - 15:10
1985 XJ6
Thanks Bill,
I've been an Old 50-69 Chevy collector until I started this 85 XJ6 project.
NOW I'M HOOKED :)
Bill, this car is a work of art. The body lines are amazing, the front grill, the bonnet, the curves, the ride are all amazing...
I'm getting aquianted with some of tools here at this web site and found the library section WOW. I can spend several hours washing her , and every time it is a pleasure to enjoy her sexy curves and works of art lines on these babies.
Now looking forward to the learning process to get her running again :) Hopelfully myself, with the suggestions i've recieved here in this forum.
Thx again Bill
Marco
Submitted by wpritchard2@tx… on Mon, 09/05/2011 - 11:17
Submitted by acrcllc@gmail.com on Sun, 09/04/2011 - 19:49
Submitted by wpritchard2@tx… on Sun, 09/04/2011 - 18:07
1985 XJ6
A melted catalytic converter, dirt in the fuel system or a bad ignition will all give those symtoms. The igniton normally would work cold but break down after getting hot..
I had the same symptoms on a 79 Rolls and it was caused by dirty gas after I had rebuilt the entire fuel system. Carbs, fuel filter, pump and tank cleaning. After it was filled up it started running poorly. Since I had just completely overhauled the fuel system, I and my mechanic dismissed the thought that the new problem was fuel related. It felt like an ignition problem, but ignition testing proved otherwise. Finally I decided to take the carbs apart again and found the the problem (dirt). Feathering the gas would work because the fuel demand increased slowly, but not enough to drive the car under a load.
A qualified mechanic can eliminate the ignition as a problem with test equipment. The exhaust might need to be removed to check for blockages and fuel flow can checked with pressure gauges and measuring fuel flow from the pump.
The fuel filter (a cannister with an input and output on either end) should be able to be found by tracing the fuel line. On an 1983 XJ6 - Open the trunk and remove the carpeting on the bottom. Lift the wooden cover to access the spare tire. The fuel filter should be located in front of the spare tire in a container bolted to the side of the spare tire compartment.
The actual regulated fuel pressure at the fuel rail, which should be 36 psi. Disconnect the hose to the cold start injector from the fuel rail and use the now-vacant nipple on the fuel rail to attached your pressure gauge
PS The fuel runs through the AC system in order the prevent vapor lock
Submitted by acrcllc@gmail.com on Sun, 09/04/2011 - 17:17
Submitted by acrcllc@gmail.com on Sun, 09/04/2011 - 17:16
Submitted by acrcllc@gmail.com on Sun, 09/04/2011 - 15:58
Re.: 1985 XJ6
Edited on 2011-09-04 15:59:52
Ahhh Yes Robert. Thank you. I do have a really good Jaguar mechanic about 40 miles out, however, when i heard this fuel/air conditioning issue, my thought first was to come to here at this forum to discuss with actual owners to get some insight regarding what i heard first. Thi is my first Jaguar, I've been a old corvette and classic chevy owner until now and I learned with my old corvettes to ask around first.
Any other thoughts PLEASE post guys THANKS a million. Marco
Submitted by bob5837@roadru… on Sun, 09/04/2011 - 14:32
1985 XJ6
Why not take it to a qualified Jaguar mechanic and save yourself a lot of grief? It could be a lot of things. A "good Jag mechanic" can usually diagnose the problem fairly quickly and provide you with a repair estimate before he actually starts the repairs. Just my thought.
Submitted by acrcllc@gmail.com on Sun, 09/04/2011 - 12:13
1985 XJ6
Thanks William and Doug. Well lets see, it started a bit over a month ago, when the weather started to get hot now that i reflect back. It acted like it was was a bad miss or ignition. I put new cap rotor plugs made sure i had spark checked plug wires. still not running right. I can get it to run if i feather the gas pedal, however if i try to idle or step on the gas it runs really rough and dies. two years ago all the fuel was dealt with. ALL New relays, new fuel pump filters all are the ggod stuff or proper replacement i.e bosch fuel pump etc.
On Friday a man came by to admire the Jaguar in the garage said he had an 86 XJ and that he found out through alot of calls and heartache that 83-87 have problems with running properly in the heat due to how the fuel runs through the air conditioninf system. Hummm.So I've looked to you all for some experienced support.
Where is the fuel filter?
What is the filter like item in the engine compartment off the fuel rail? Is that a regulator or filter?
Any help on how to check if its coil or the ignition booster amplifier?
HELP Mr Bogeled
Thanks.
Submitted by dougdwyer1@com… on Fri, 09/02/2011 - 22:22
1985 XJ6
Marco, are you sure it's a fuel problem? What things have you already checked? How and when, exactly, does the problem occur?
Tp prevent vapor lock there is a fuel temp switch on the fuel rail that allows max fuel pressure if the fuel gets too hot. It's brown plastic and has two vacuum hose. Is it hooked up?
The ignition moduel and coil are both known to give trouble in high heat situations. Sometimes the symptoms feel like fuel starvation.
With some more details we might be able to narrow this down.
DD
Submitted by pritchard@cox.net on Fri, 09/02/2011 - 21:46
Have you check the hose connections? I solved the leak problems by replacing all hose connections that connect to fuel injectors and now it runs smoothly. Does not stall anymore. Maybe try looking at it. Yes it can be a royal pain in neck with fuel problems!
