help someone please 86 xj v12 no start car has 73000 mile fuels pump come on injectors click seems to have spark but all i get is popping out of the intake and i won't fire i have changed that cap rotor plugs wires to no satissfaction i get the same result any one have a clue
thanks rich
Submitted by endlesnytes@aol.com on Fri, 04/09/2004 - 23:23
well this might sound out there but if you unplug the coolent temp [left front head] sensor some v12s will not start they will spit and sputter and load up point is maby bad temp sensor good luck ps jump that plug if it is that sensor im pretty surr it will start right up let us know
Submitted by silver007@shaw.ca on Mon, 03/01/2004 - 14:56
Hello Richard,
although not a real breakdown specialist,my 83 only goes to shows and slalom races. Recently a friend of mine hed a SIMILAR SOUNDINDG PROBLEM . After much knashing of teeth and burning the midnight oil,and changing the crank sensor, he was advised to put on a new distributor cap, result, vroom vroom. I know we always suspect the worst, and sometimes it probably is, but sometimes we forget the simple things, basic tune up parts which on lesser cars are changed almost like your socks, put on a new cap and rotor, if it starts or not then put on a new set of wires, and instal new set of NGK V groove PLATINUM spark plugs .
I HAVE INSTALLED a MSD Ignition box on my car, the car starts more readilly now, also the later single IGNITION COIL, eliminating the need for the 2nd coil @ the front near the rad.
Good luck.
silver007atshaw.ca
Art Dickenson.
1983 XJS GT "Silver"
Pacific Jaguar.ca
Submitted by dougdwyer@eart… on Mon, 03/01/2004 - 09:46
Since yours is an '86, it won't have a crank position sensor. The ECU is in the boot/trunk, upper right side, behind trim panel.
Since you have good spark and you hear the injectors clicking, I'm wondering if you have enough fuel pressure? Do you have a pressure gauge?
Doug Dwyer
JDRC/NWA
Submitted by SRautomotive@o… on Sun, 02/29/2004 - 09:02
has great spark checked it today fuel filter is clear if i take the crank sensor down is there a way to check it second can u tell me where the ecu is located in the car? it almost sounds like the timing is out 180 degrees but i know for a fact the distibutor has never been out of the car
rich
Submitted by kallcomm@cac.net on Sat, 02/28/2004 - 22:32
Rich
Make sure the spark you see is a good spark. I had two coils fail. They would put out a weak "orange" colored spark instead of a "white" spark. You said the fuel pump comes on, but are you getting fuel to the fuel rails. You might have a clogged fuel filter. Also check the crank position sensor.
Greg XJR-S
