Hi, When i start my car the engine does not run smoothly at idle speed. It slows down (almost stalling) and then speeds up. This slow and fast idle keeps going for a few minutes and then smothes out. Any suggestions?
Submitted by brianscats@sym… on Tue, 11/23/2004 - 00:22
Submitted by pete4t@ncia.net on Sat, 11/06/2004 - 06:02
Re.: 1989 XJ6 - Engine will not hold smooth idle
I'm having the same problem. I haven't got into it yet, but it lookd like the place to start.
The picture below, provided by Pascal Doxarve, shows the Auxiliary Air Valve (AAV) on the Jaguar XJ-S V12. The AAV contains a piston that moves under the influence of a wax bulb, much the same way an automotive thermostat works. The AAV is mounted on top of the left rear coolant manifold, putting it directly in contact with coolant coming out of the left bank head.
The movement of the piston uncovers an opening that permits air coming in via the hose at left center of this picture (from the left air filter housing) directly into the left intake manifold via the hose at top center of this picture, thereby bypassing the butterflies. The balance pipe across the top rear of the engine allows air to the right bank so the car runs on all 12 at idle. As the engine warms up, the piston moves to cover the opening and reduce air flow and bring the idle back down to the normal warm idle speed.
Members of the discussion list will confirm that the AAV is a common source of trouble, with the piston getting sticky or jammed. It's not intended to be rebuildable, but several owners have found a way.
There are also some indications that there are differences between AAV's fitted to early vs. late cars and UK- vs. US-spec. Some may provide more air when cold than others. Clearly, if you want your car to idle when cold as intended, you need to get the correct part for your car.
The bolt head protruding downward from the AAV is the infamous idle adjustment screw. The bolt itself obstructs a passage within the AAV, separate from the thermally-controlled piston. The farther this bolt is screwed in, the more the bolt obstructs the passage, and the slower the engine idles.
Good luck,
Pete Forte
'92 XJS Convertible
Since it is a Series 4 sedan not a V-12 it will not have the AAV at all.
The first check would be the coolent sensor and/or the ambient air sensor
in air intake 90 degree tube just after the air flow meter.You could always
check the Factory Service Manual.
Brian Scriven.
1957 XK 150 D.H.C.
1962 MK 10 4 manual o/drive
1965 3.8S
