Yesterday was the first nice day we have had in quite a while, so I decided to charge the battery in the Jag and take it out for the years first drive. When I hooked up the charger a klaxon horn started to sound and the onkly way to make it stop was to remove the battery lead. I removed the neg and gave the battery a full charge, however now anytime I reconnect the neg lead this super loud horn goes off and a red LED on the steering column keeps blinking. It blinks in sets of 3 blinks then it goes off for a few seconds. I am told that there is a back-up battery and a valet switch, I can't find either. This system has also disabled the ignition, therefore the car won't start. I do not nor have I ever had a remote key fob for this car. The only keys are the ignition and the trunk door, etc. key.Is there a way to turn this off,disable, or a work around that I can use to get this problem solved. Don't even know where to start and I would appreciate any help that I can get. Bob K 1990 XJS conv
Submitted by Anonymous (not verified) on Sat, 10/29/2016 - 02:12
Submitted by marshall@moret… on Sun, 03/25/2007 - 17:25
1990 XJS Alarm
Marshall Moretta
'96 XJS 4.0 Convertible
My car does the same thing, but the alarm goes off after a few seconds. It was stressful the first time it happened, but doesn't seem to harm anything. I connect the positve charger cable to the positive battery post and the negative to the 1/4"dia trunk latch bar at the bottom center of the trunk opening. I do not remove the negative battery lead.
Submitted by john@silvereag… on Thu, 03/15/2007 - 11:00
1990 XJS Alarm
I have a toggle switch tucked away on the underside of the steering column, I was told this is the on/off switch for the alarm. Have you tried turning that off?
John Howard
1990 XJS Classic Convertible
2003 XJR BBS
Submitted by robert.kepner@… on Thu, 03/15/2007 - 09:54
1990 XJS Alarm
Thanks, however I dont have a remote key fob. I have tried locking and unlocking drivers door, turning ignition on and off without starting car, checking all obvious switches, still LED continues to flash and alarm sounds. I would just disable alarm horn, but the ignition is still disabled. So no start. I have a wiring diagram of 1990 Security system that shows a back up battery and valet switch. It also shows a start inhibit relay. It does not give a location or numeric designation so I can't find them on Jag wiring diagram.Maybe I'll just turn it into a planter. Thanks for all your help. Bob Kepner 1990 XJS Conv.
Submitted by john@silvereag… on Wed, 03/14/2007 - 16:14
1990 XJS Alarm
Same thing happened to me, I got rid of it by pressing the remote button a number of times. But it does raise an interesting point as the blips and tones emmitted when you press the remote are a mystery to me.
Anyone know what the sequence/logic is?
John Howard
2003 XJR BBS
Submitted by y2kgolf@hotmail.com on Tue, 03/13/2007 - 09:36
1990 XJS Alarm
Robert,
Maynard is correct. It is the same on my 1995 XJS.
Martin
1995 XJS Convertible
Submitted by mghirsch@netzero.net on Mon, 03/12/2007 - 17:13
1990 XJS Alarm
On my 94, turning the key on and off 4-5 times, without starting the engine, turns off the alarm. I don't know if it resets by itself when turned off.
Maynard Hirsch
94 XJS v12 Coupe
86 XJ6
91 XJS (RIP)
78 MGB
67MGB
Submitted by y2kgolf@hotmail.com on Mon, 03/12/2007 - 16:54
1990 XJS Alarm
Robert,
I remember reading about shutting off the alarm system manually on my 1995 XJS. I will try to find the answer for you tonight and let you know.
Martin
Alarm of the past and for historical. The images of the past and historical. The suggested terms of the best essay by http://www.besstessays.net/ imposed and offered with the adjustment of the remained and instituted.
