Fuse panel 3 has zero voltage to any of the 5 amp fuses??
Submitted by asemastermecha… on Tue, 11/02/2004 - 15:41
Submitted by rex@rexwebb.com on Thu, 10/21/2004 - 02:10
Re.: 1994 XJ12 Dead Fuse panel
Thank you for your reply, voltage test with meter shows all wires with zero voltage. There are two wires larger that are color coded white with light purple type stripe which looks to be able to hold more current. Followed them forward to dash area and test still show zero voltage through insulation test too?? It seems where the panel 3 in center console gets original power is possible source???
Submitted by asemastermecha… on Thu, 10/21/2004 - 01:11
Probe the rear of the fuse block for power.
Fear you may have a broken wire or fuse panel circuit.
whunter
ASE Master Mechanic
http://www.woodwardauto.com
asemastermechanic
juno.com
A broken wire in one of the fuse panels would not shock me.
I see this roughly five times per year.
You need wire diagrams to work around or repair this issue.
whunter
juno.com
ASE Master Mechanic
asemastermechanic
