the speedometer needle is bouncing erradically, especially when going over bumps. Any ideas on how to solve this problem? over 75 mph it seems to be fine.
Submitted by SE98-32482CJ on Sun, 03/14/2010 - 07:43
Submitted by bonnettoboot@e… on Sun, 03/14/2010 - 00:20
85 XJ6 speedometer
Doug T. it sounds like you need to drive faster,lol! Doug D may be right, the transducers were very unreliable. I recall having a similiar reaction from one, it seemed to only work on drive, not on overrun. It took us a couple of days to discover that the output shaft nut was loose!
Submitted by douglastanger@… on Sat, 03/13/2010 - 22:06
85 XJ6 speedometer
Thanks Doug, I'll check it out tomorrow and see if I can find anything. I appreciate your fast response. Happy motoring, DT
Submitted by dougdwyer1@com… on Sat, 03/13/2010 - 21:54
85 XJ6 speedometer
Erratic speedometers on these cars are most commonly caused by a failing transducer, located on the right side of the transmission, about $100, and easy to replace.
However, the "over bumps" aspect suggests a loose connection somehwere along the line or perhaps a chaffed wire. I'd check that angle first before replacing the transducer.
DD
I think Doug D hae it. I have never experienced a bouncing meter due to a failing drive--(they normally have bouts of working vs not but bumps have never had a play except with loose or frayed wires but I can see where a loose unit might do that.
