Body interior immaculate blown head gasket. Want to put maybe a AJ6 motor transmission or maybe a V12. Any thoughts ideas or suggestions. Many Thanks
Submitted by xj12@roadrunner.com on Fri, 11/20/2009 - 13:51
Submitted by david.wittevee… on Wed, 11/18/2009 - 13:51
86 XJ6 Blown head want to put a newer faster engine/trans any suggestions
If you're willing to try something different... Take a look at the GM smallblock V8 driveline conversion kits at 'Johns Cars' - http://www.johnscars.com.
Submitted by bonnettoboot@e… on Sat, 11/14/2009 - 16:06
Why not just redo the 4.2?
Submitted by dougdwyer1@com… on Sat, 11/14/2009 - 15:49
Several have transplanted AJ6 engines into Ser IIIs. Not exactly a direct bolt-in by any means, but doable. If you search the Jag-lovers archives you'll find info and pics.
The V12 swap would be doable as well but, again, lots and lots of work no matter how you slice it.
In both cases I'd say that actually fitting the engine in place is the easiest part, compared to sorting all the details
DD
GM LT-1 witha 700 r4 is a real easy swap
