Need some help. I have a 89 XJS that cranks but won't start. Not getting spark form either coil. Car had electrical short and fire between the radiator and the ignition coils. Replaced wiring and found one blown coil (left bank). Replaced the coil and car was running rough with limited power. I checked the cap and cleand the plugs all is good. I noticed the drivers side cat was cherry red and the car stalled. I let it cool down and still no spark. I checked the fuses (right side under the dash) all are good.
Submitted by Charles.Arico@… on Sun, 08/23/2009 - 15:24
Submitted by silver007@shaw.ca on Wed, 07/22/2009 - 01:30
89 XJS cranks but won't start
	Hi Charles,
                                  no doubt you have Marelli ignition . the rotor is burnedthrough its insulation on its bottom electrode........buy a new one.. call if you want more info than I can type,
            Art              604 465 7244........
Thank you for the responses. Turns out both Ignition Coils were fried. Replced and running on six cyl now. I Have a bad ignitor.
