My local dealer just installed a new driver's seat memory module. The old module was only intermittently moving the seat fore and aft. The new module seemed to work for the first day. After I adjusted the height of the seat downwards as far as it would go and sat in the car, the seat once again won't move fore and aft. I am now suspecting a wiring problem external to the module. Has anybody else experienced this?
Mark
Submitted by coolairyak@aol.com on Tue, 11/18/2003 - 13:32
Mark - I have a 1997 XJ6 (X300) with driver's seat not moving. Checked fuses - all OK - what else? Did you sort your seat switch pack problem out?
I have a knocking sound from around rear shock absorbers. Sounds as if A- bushes gone so frame hitting bodywork. Have you come across this problem?
Breff
Submitted by pascal@jcna.com on Fri, 06/06/2003 - 10:38
Mark
the seat memmory module is one of the few recuring problems on the X300. they usually fail after a few years. Some have been able to repair them, saving a lot of money... but if you had this done by a dealer, they shoudl be able to make sure the replacement work! I wouldn't mess with it since there is a 1 year warratny on replacement parts...
Pascal Gademer
72 E-type 2+2
00 XKRCoupe
99 XJR
