I am concerned about the large pedal pressure required to stop my car.
Mechanic says servo is working. My memory of drving a friends 67 roadster some years ago is tha tthe brakes had a nice feel to them.
Suggestions? Pads are new.
I suppose as I am new to E type ownership (atually my first Jaguar) I will have numerous dumb questions to fill the forum with.
Many thanks
Paul Rivera, 1967 XKE 2+2
Submitted by NE52-32043 on Mon, 02/23/2004 - 11:14
Submitted by bonnettoboot@e… on Sun, 02/22/2004 - 18:18
Re.: brake pedal pressure, 67 2+2
To check the servo; switch off the engine and pump the brake pedal until it gets very hard and hold it there, now start the engine, if the pedal moves down the servo is working ,if it stays hard it isn't. If it is working and the brakes are inefficient you may have seized callipers at the rear, Check it out
Jaguar affectionado and etc.
Good suggestions by William. Also, have the brakes been bled recently. If not, have it done (if you don't know how to do it yourself). Be sure to use fresh fluid.
Steve Weinstein
'72 E-type 2+2
'70 XKE FHC
