Are you saying the horn, interior lights, clock and headlights do not work when it dies? If so, are you sure? Mr. Eck's solution of the ignition switch sure would make it easy to fix. Let me know and I will look at the wiring diagram and see what other possibilities I see. Mr Eck and Potter can check anything I come up with because I can miss the obvious now and then, as I did with the ignition switch.
