Hello,
So I have no problem starting my car, (67 2+2 ser.1-1.5) and drive it, once I turn off the engine the car will not start until completely cool down.
any suggestions?
thank you
67 2+2
Submitted by jason.rudd@gmail.com on Mon, 04/25/2016 - 18:22
Post back your results I'm interested in hearing. Also another thing I considered was moving where my coil was mounted. Seems different cars have it in different places. Here is an image (not my car) which shows where my coil is:
http://www.classicarimages.nl/common/pictures/lexclassics/2011/0111/supe...
Here is an image that shows a coil mounted closer to the radiator-further from engine heat.
http://www.classicarimages.com/common/pictures/imparts/2010/0210/supersi...
Submitted by jason.rudd@gmail.com on Mon, 04/25/2016 - 17:57
I had some issues myself and it was suggested that the Ignition coil could be the issue. I replaced the coil but also learned how to drive the car better so not sure what did the trick ;) Good luck!
