Harry; I am unaware of a video. Richard Liggets book that you can purchase from JCNA is a big help as it has diagrams of all assemblies and subassemblies.
         Sill chrome strips may be removed by tapping the upper edge with a screwdriver  along the entire edge a little bit at a time.
         The radio, if like my 2+2 Auto with A/C can be removed by removing the two chromed nuts at the front of the speaker surround and gently pulling out on the surround and then pulling it towards the back of the car.
          Remove the inside of the cubby box,  there are some screws that are used to attach it to drive shaft tunnel. You then have to remove the shift lever surround which I am unsure how it is attached as it may not be the same as my auto surround, Sorry, my help ends here before I get you into trouble.
           Good luck, Joel.
