I just got back my driver 66 E-Type FHC from restoration and the dash lighting is very very dim -- it appears non-existent on the lower of the toggle switch settings and far less than I recall from ownership of a previous E many years ago on the top setting. The restoration shop says this is normal,that you are lucky to see the output "on the night of a global eclipse," but I would like to increase the brightness -- I can barely see the speedometer. Is there anything I should do to check or do to increase the brightness?
Submitted by SE98-32482CJ on Thu, 08/12/2010 - 07:38
Assuming all bulbs are good and dirt is not an issue it sounds like the switch had built too much resistance from age--try by passing the switch and see how it is--you can put in brighter bulbs but heat from them might cause some damage. Also I would check the wiring to the switch--perhaps they (restorer) wired the switch improperly.
