My XJ-S runs like a champ. However, she will not go past 100mph and the rpm gauge isn't even close to red lining. I was told by a friend that the V12 Jags were fitted with a restrictor before being exported to the USA because of Emissions Standards. Is this true? If so, is there any way of removing/resetting this restriction?
Warm Regards,
Will Wilkins
Proud Owner of a 1989 Jaguar XJ-S V12
Submitted by Anonymous (not verified) on Wed, 01/17/2018 - 05:30
Submitted by SE56-39631J-J on Sun, 06/18/2006 - 20:48
Does My XJ-S Have A Restrictor (Governor)?
gail&a.w.amanns vonore tn. 99xk8 conv. 93 xjr-s coupe if you have one that covers the '93 xjr-s i would be interested. thanks awa amanns
tds.net
Submitted by SE56-39631J-J on Sun, 06/18/2006 - 20:45
Re.: Does My XJ-S Have A Restrictor (Governor)?
Edited on 2006-06-18 20:48:08
tds.net also i think that there is a speed limit controll on the v-12 at about 157 mph.
Submitted by dougdwyer@adel… on Sat, 06/17/2006 - 13:41
A V12 XJS can be quite a challenge to keep on the road....lots of (usually) small repairs required, not only Jaguar-specific quirks but also typical age-and-mileage services and replacements.
I have umpteen different XJS manuals and CDs, but thanks for the offer :-)
Doug Dwyer
Longview Washington USA
1987 XJ6 Ser III
1988 XJS V12 Coupe
Submitted by wwilkins@adelp… on Sat, 06/17/2006 - 10:26
That is great news. Thanks for the information. I purchased this kitty about 8 months ago and it's been quite a learning experience ever since. So far, I had to replace the alternator, steering pump hose (aargh), and a radiator hose and that was truly educational.
Hey, I bought this awesome CD on Ebay called (Jaguar XJ-S to 1991 - Workshop Parts & Service Manual)...apparently, someone digitally copied the entire XJ-S manual into PDF format. If you are interested, I would gladly send you a free copy of it. It has been a blessing because you can print out just the pages you need and if they get messed up while working on your Jag...you can always print them again. Thanks again.
Will Wilkins
Submitted by dougdwyer@adel… on Sat, 06/17/2006 - 04:22
Nice Jag. You should be able to go to 6500 rpm and around 140+ miles per hour if the old girl is well tuned
Check for clogged exhuast and/or fuel filter
There were no "restrictors" installed....
Doug Dwyer
1987 XJ6 Ser III
1988 XJS V12 Coupe
I like the models og XJ-S which are really good. I have read the reviews about this car at http://www.australian-writings.net/. You can contact a manufacturer to get the solution.
