Gentlemen:
A couple of days ago, first the LH, then the RH indicators failed to operate. I checked to see if anything else was going on, and found that when switching on the lights, the fuel gauge went way past full. This happened with or without the engine running, with the aux position on the ignition switch on or off, and with the key out of the ignition switch completely, thus with everything off.
I would be most grateful for any ideas on a diagnosis.
Best regards,
Chris Holbrook
Submitted by stevejag@sbcgl… on Tue, 07/23/2013 - 12:19
Try checking and cleaning the two ground points in the boot, in the vicinity of the tail lights. Probably behind the trim panel, I just can't get that mental picture exactly where they are, I made the mistake of going to sleep once. :-)
