My 89 XJ6 starts up fine and after about 12/15 miles driving the engine drops down to about 1000/1200 rpm and will not move up. Engine starts to run rough and sounds like it may be backfiring. I can drive it home and after it completely cools down it will start up again for another cycle. Changed fuel filter, pump and plugs to no avail. How many sensors control the engine rpms? Can anyone help?
Submitted by asemastermecha… on Thu, 12/04/2003 - 23:11
Submitted by asemastermecha… on Thu, 12/04/2003 - 23:00
Re.: engine drops down to 1000/1200 rpm after about 12 miles
Hello Don Horton
I need more data:
How many miles on the car?
Is it a daily driver or a show car that is in storage much of the year?
Is the fuel tank full, don't trust the gauge?
Did this start after filling the fuel tank?
Can you get fuel pressure reading while it is malfunctioning?
When was the fuel filter last changed?
Have you ever had fuel system work done on the car?
What and when was the last garage service done?
Have a great day.
whunter
ASE Master Mechanic
Bloomfield Eurotech
45671 Woodward Avenue
Pontiac, MI 48341
Work Phone 248-334-6400 Fax 248-334-2363
asemastermechanic
juno.com
Submitted by jdonhorton@int… on Tue, 11/04/2003 - 19:10
Michael.
Thanks for the tip. Tried it but didn't help. Changed the temp coolant sensor and that didn't help either. Checked the converters and they are not stopped up. Open for any other ideas. Thanks again.
Submitted by Mjabara@redroc… on Mon, 11/03/2003 - 03:00
Try driving without the gas cap; if it runs OK, then you have a vacumn problem in the gas tank!
Michael Jabara
Las Vegas, NV
1954 XK-120 OTS
1997 XJR
Hello Don Horton
I need more data:
Have you replaced all the relays under the bonnet?
Have a great day.
whunter
juno.com
ASE Master Mechanic
Bloomfield Eurotech
Pontiac, MI 48341
asemastermechanic
