I just finished cleaning my fuel injectiors after having a rust problem in the fuel tanks.Reconditoned the tanks changed the plugs and wires,rotor and cap, fuel filters,thermostat and oxy sensor. The car runs great until it warms up then it will not rev up smoothly and dies out.Temp is at 90with no overheating problem.Have tried two different coils also. Carl
1986 XJ-6
Submitted by SE98-32482CJ on Fri, 03/14/2003 - 20:35
It is not what you say it is what you do not say. Was it doing this prior to the tank(s) removal? If not I would check to see if the flow from the tanks is correct. I assume you used sealer which also clogs fuel outlets. Those tanks are also vented to cannisters and if this is blocked they will pull a vac. which your fuel pump can not overcome. When it quits carefully open the filler on the tank you are on. If you get a big wooosch you have clogged a line.
George Camp
