Has anyone had problems with their heater core? I have an 88 convertible XJS. When she gets warm and you stop, all the antifreeze comes out from the bottom in the area of the passenger side by the dash underneath. Someone said it may be the heater core. Could it be? If not, any other suggestions that it may be?????
Submitted by dougdwyer1@com… on Thu, 03/29/2007 - 20:40
Submitted by mmhoward91@tul… on Thu, 03/29/2007 - 19:55
Heater Core
Is this a hard part to replace? And most importantly...is this bad?????
Re.: Heater Core
Edited on 2007-03-29 19:56:10
Thank you so much for the reply. Couple of questions, is this common?
Submitted by dougdwyer@adel… on Wed, 03/28/2007 - 21:32
Heater Core
Most likely IS the heater core
Doug Dwyer
Longview Washington USA
1995 XJR
Fairly common, yes. If its leaking, its bad.
As far as ease of replacement goes, well, its easier than on some jags (and many other cars) but still a bit of a job......probably 4-5 hours labor for a reasonable DIY person who has never done it before.
Doug Dwyer
1995 XJR
