hi,i have 89 xj6 with hidroulic rear shock absorbers.and i want to change them to regular ones.but i have no idea what to do with hidrolic pump(or compresor) and all the houses.please help-i know it`s easy-to-fix thing
thanks in advance
torinoatrepairman.com
Submitted by triath5147@msn.com on Wed, 01/14/2004 - 22:31
I have an 88 XJ6 but I believe they are similar. Actually the hydraulic pump is necassary for your power brakes. In fact you don't need to remove anything. All you have to do is, , on the left rear strut there is a bleed screw for bleeding the hydraulic system. Retrofit the new struts, remove the hydraulic lines from the rear, and use the bleed screw to block off the hydraulic outlet up at the valve block in the engine compartment. They just happen to be the same size threads, and compression type. SO it is a perfect fit.
If you have any specific questions. you can e mail me at triath5147 @ msn.com or post it here
