Can anyone suggest what is best to lube hoses for putting onto fittings and pipes? I've tried it all: WD-40, well-bearing grease, lithium grease, Vaseline. They all enable the hose to go on smoothly, however, a year later, the hose is welded to the pipe and I end up having to slit the hose to get off. Any suggestions?
Patrick McLoad
#1E1445
Submitted by SE98-32482CJ on Mon, 08/25/2003 - 18:32
Submitted by therays@flash.net on Mon, 08/25/2003 - 15:42
Re.: Hose Lubricant
Patrick: I too have tried a variety of substances over the years, inc. WD40, silicone spray and Vaseline. A high quality silicone spray seemed to protect the rubber and eased later removal. I also use it to detail hoses and other rubber fittings, also weather stripping. Also works pretty well for delaying build-up on battery terminals.
Glenn Ray
'66 E-Type OTS
NC19-Michigan
Submitted by warren.hansen@… on Sun, 08/24/2003 - 20:09
Re.: Hose Lubricant
When I put a new fuel hose on my car last year (from the filter to the carbs) I used dishwashing liquid; went on as easy as pie. Haven't tried to remove it -- don't expect to for at least 20 years! -- but I can't see why it would weld the hose to the fitting.
HTH,
Warren Hansen
70 E-Type FHC "Silver Bolide"
96 X300
Use DOT 5 that was expelled during bleeding. Works great on all rubber inc. tires or tyres and will not bed or build up. Cheap too unless you remember what it cost going in.
George Camp
