the speedometer comes only works intermittently. The manual tells me how to fix the mechanical drive, but I have an electronic system. Any hints on what might be wrong? Does anyone know where the electronic sender is located?
Submitted by SE98-32482CJ on Tue, 04/08/2008 - 18:00
Submitted by dougdwyer1@com… on Tue, 04/08/2008 - 08:51
intermittent speedometer
The transducer is the most likely culprit, left side of the transmission if you have a V12 with the TH400 trans.
Couldn't hurt, though, to check/clean the connections at the printed circuit behind the instrument cluster. They are known to get corroded/ The cluster is pretty easy to remove.
DD
David before you start removing things watch the next time your speedo goes out--perss your instant fuel milage button--if it reads zero or very low leave the instrument head alone and change that transducer!
