I recently bought a nice xjs 1996 convertible. While driving this car from US to Canada I noticed her strange behaviour. Car does not slow down in a normal fashion when I remove my foot from the gas pedal.  It is driving with the same speed and takes it several kilometers to notice a slower speed. It did not bother me on highways but in the city I have to use my brakes often. Is it normal for this model?
Peter
Submitted by peterszkup@hot… on Tue, 03/27/2012 - 10:34
Submitted by peterszkup@hot… on Tue, 03/27/2012 - 10:31
Submitted by dougdwyer1@com… on Tue, 03/27/2012 - 01:17
JXS not slowing down
An easy place to start is to clean the throttle body. No promises but there's a decent chance that'll solve the problem.
DD
Submitted by rcmaury@bellso… on Mon, 03/26/2012 - 16:12
What is the idle speed in neutral? Should be around 800 RPMs. The 6 cylinders have been known to have automatic idle problems. The idle is controlled by the ECU and sometimes goes bad causing a high idle which cause this symptom.
Submitted by SE21-64524 on Mon, 03/26/2012 - 13:37
Hi Peter: what is the color combination of your new '96 XJS? Ali KIng
Submitted by SE21-64524 on Mon, 03/26/2012 - 13:36
Submitted by peterszkup@hot… on Sun, 03/25/2012 - 23:43
Submitted by bonnettoboot@e… on Sun, 03/25/2012 - 23:38
It sounds like the throttle is not closing properly, check it when idling, if it only happens on drive, then, when it occurs engage nuetral & stop then check the accelarator linkage. Its funny so many came in from Canada now they are going back? They are the best buy on the sports car/convertible market.
Thank you.
