I have replaced both fuel pressure regulators, fuel pump, fuel hoses, coil,ignition module, battery, rewired the ignition pickup replaced the grounds. Perfect fuel pressure, The engine will run perfect on one day and then will not idle above 300rpm on other days. Tired of throwing money at the problem, would like to rule out the ECU does anyone have an extra working ECU that I could borrow? Thanks.
Submitted by coventryclassi… on Mon, 03/12/2012 - 14:40
Kevin, I have a couple of the DAC 6335 84526H Lucas 16 CU control units that were removed from running cars for a V8 conversion. Would be happy to sell cheap or lend with deposit.One is date coded 3788 the other 3796. Call me or send an email if you still need them. Thanks Tom (407)298 1358
