My car is left hand drive (USA). The ignition switch uses a Britax key. The car has factory air conditioning and the ignition is in a steering column lock on the right side of the steering column. I need a whole new unit with shear bolt, key, cylinder, lock, lock housing. I already have the plastic switch that mounts to the back of the housing, but will take an entire assembly.
Thank You,
Chuck Minahan (Lectrkbluz
aol.com)
Submitted by bonnettoboot@e… on Mon, 05/15/2006 - 01:16
Submitted by shanalmay@cox.net on Sun, 05/14/2006 - 00:32
Need Steering Column Lock for 1971 E-type
call Terrys Jaguars 618-439-4444 that is where we get all our parts for restorations ask for Jake at ext 104 he will be able to help you out. Usually get my parts within 2-3 days. If you need any other help email us or call
shana may owner
h and m customs
479-790-0956
hmcustoms
cox.net
specializing in jag restorations
If you have difficulty finding the steering lock assy it is possible to simply eliminate it by fitting a simple "earlier type" key only switch. Jaguar affectionado and etc.
