Edited on 2008-02-25 21:25:48
A rebuilt 1987 Jaguar XJ6 engine - used Valvoline VR-1 20-50 "Not Street Legal" for break-in oil. Now using VR-1 20-50. Any thoughts on the best motor oil for this motor? I've been told to not use synthetics.
Submitted by zurdo_1@univis… on Tue, 02/26/2008 - 09:02
Submitted by ekimp252@aol.com on Tue, 02/26/2008 - 08:47
Re.: Motor Oil For 1987 Jaguar XJ6
What aboul the Castrol GTX 20W50" High Mileage"?Anyone have any info on it?That is what I am using in my 85XJ6,40K on the clock,but I'm thinking higher due to other issues.Thanks.
Mike Pressley
85XJ6
00XJ8
Submitted by smose2400@sbcg… on Mon, 02/25/2008 - 21:06
UPDATE
After more research it seems clear that the zinc levels in Castrol 20-50 GTX have been reduced over the years. Castrol has introduced a new oil, if you can find it, called CASTROL SYNTEC 20-50 for "Classic Cars" (100% synthetic) which has an additive package bringing the zinc level to at least 1,400, accoring to the Catrol rep to whom I spoke today. They will not comment on the zinc level in GTX 20-50 saying that is "confidential." For now...I am staying with conventional oil Valvoline VR-1 Racing Oil which has an additive package for zinc and phosphorous with the zinc level at 1,300. My concern with synthetic oil is possible leaks.
Scott
Submitted by SE21-31278 on Mon, 02/25/2008 - 17:52
I second the castrol 20w50. It's all I use.
Bill Cooper
1973 XJ12
1976 XJ12C
1985 VDP
1995 XJR
Submitted by zurdo_1@univis… on Fri, 02/22/2008 - 23:11
Edited on 2008-02-22 23:12:39
if you ask the Jaguar mechanics I know, who rebuild 3.8 and 4.2 Jaguar engines, they'll tell you Castrol 20W50. so that's all I use.
But before you go anywhere, go to the GENERAL DISCUSSION (First forum in the list), and read the article on oil, "Oil in Old Cars".
I've been told by three different Jaguar techs, in three different States, to not use synthetic oils in the 4.2 or 3.8 engines so I never do. (for the same reason, it seeps through gaskets more easily, creating leaks). Besides, synthetic oil is more expensive, so why throw money away?
I have not seen the Castrol High Mileage 20W50 at Walmart. I never believe the odometer (mileage) reading in these cars. Speedos can be easily replaced. If it says "28k" I always think "128k". If the car has been restored, the mileage reading is definitely not real. (why would you need to restore a 28k mile car?). Unless the owner can prove the mileage, and that is another story.
