Hi All,
I'm geeting alot of vibration from the engine at idle that dissipates on accelleration. I'm thinking that the timing is off and plan to re-adjust it this weekend. Last week I looked at the distributor cap and spark plugs (unfortunately it wasn't that easy). The other thing is a slight squeaking sound that my engine is giving me at idle. Could it be a rod or a pump ready to go? Does anyone have any suggestions?
Best Regards,
Sean
ps-Thanks for the help with my cooling system. I ended up by-passing the thermo switch and connecting the fan to the coil for a constant run of both.
Submitted by htech@cwnet.com on Tue, 07/26/2005 - 18:55
Submitted by htech@cwnet.com on Tue, 07/26/2005 - 18:28
Series 1.5 Engine Vibration and what seems to be periodic squeaking.
Squeaking sound at idle possible water pump or distributor rotor. Tom Hughes
Rather than the distributor rotor, I should have been said the contact breaker lever. If the surface of the cam becomes dry, that will squeak. Tom Hughes
