My 1997 XJ6 has just reached 90k miles and runs perfectly.
Other than the usual oil change, are there any special service
items that should be done at 90k?
By the way, I just replaced the tires with Fuzion ZR's. The difference
in ride and handling is incredible. I highly recommend these as an inexpensive alternative to much more expensive Dunlop or Michelin performance tires.
Ken Law-Davis
1997 XJ6
Submitted by triath5147@msn.com on Sat, 09/11/2004 - 10:03
check your service manual for the recommended items for the mileage. But just as a rule of thumb, you should be changing transmission fluid and filters every 30,000, differencial fluid change if it is rear wheel drive. If you didn't change plugs wires and the whole shpeel at 60,000 than you better change all of that as well.
