How do you remove or replace a starter motor when you have an automatic transmission? The upper bolt appears to be inaccessable from under the car.
Submitted by W4MGB@comcast.net on Thu, 07/17/2008 - 11:35
Submitted by tolknw@comcast.net on Sun, 05/18/2008 - 17:20
Starter motor replacement with automatic transmission
I forgot to mention, it is a 1974 E type V12.
The bolt is accessed through the firewall fro inside the car.The hole should have a plug in it.Also get a mini starter.Les.W4MGB
comcast.net
