WHERE DO I START TO UN-STICK A STUCK
FLOAT ON MY '73 2+2? IT'S THE DRIVERS
SIDE REAR.
THANK YOU
Submitted by railnutz@ptd.net on Wed, 05/12/2010 - 07:25
Submitted by bonnettoboot@e… on Mon, 05/10/2010 - 21:53
STUCK FLOAT
Presumably it only leaks with the ignition on! Put a tray underneath it and switch on the ignition. Try tapping it a few times on the bottom where the float is, use a bar such as an socket extension, if it doesn't stop, then it is most likely a sunken float.
THANKS BILL
