I've got a 4 spd e type trans for my ser 2.
There is missing a bolt and retaining nut located just to the right of the shifter. What I could determine is that there is within the hole where the bolt goes in a spring and ball bearing.
It seems that is bolt is an adjustment bolt of some kind as per what I could determine.
Please comment.
A pic is below
        Submitted by m.giuliani@sym… on Sat, 11/10/2012 - 22:17
Submitted by rcmaury@bellso… on Thu, 11/08/2012 - 14:39
trans nut and bolt
The bolt and nut in question are for the reverse lock out. It is spring loaded so that you don't accidently engage reverse. The adjustment determines how hard you hit the gear lever to get into reverse. There is a spring and ball inside.
Submitted by bfahnest@gmail.com on Thu, 11/08/2012 - 08:05
trans nut and bolt
sorry my image did not up load check in the XKs catalog it will tell you what you need (or any other big supplier for that mater) Welsh or Coventry West may even have and old part they will sell you
Submitted by bfahnest@gmail.com on Thu, 11/08/2012 - 08:00
Thanks found the ball bearing, spring, nut and bolt, will install shortly,
thanks all for input!
