I have a 2004 XJ8 sedan. No where in the owners manual does it mention checking or adding transmission fluid. I think my fluid is low and need to add some. Also, need to know what type to use. Any help appreciated.
Submitted by SE98-32482CJ on Fri, 12/03/2010 - 12:46
Donna the fluid is not checked--if you are low you need to go to a dealer or a shop that is well versed in that transmission--the fluid is very expensive and difficult to add--you perhaps have a different issue in which case the dealer or shop will be able to help! Best of luck.
