i have recently replaced the nylon bushings in the upper column on my 66 e-type. though the shaft fits snugly in the bushings, there is play in the fit of the bushings to the housing (tube) which makes for some wiggle in the shaft. is this "normal" or is there a fix?
Submitted by georgejones123… on Thu, 07/28/2005 - 19:35
Submitted by SE98-32482CJ on Thu, 07/28/2005 - 16:32
upper steering column
You have some other problem. The bushings should be very snug in the outer shaft. George Camp
Nicholas,
I had exactly the same problem when I ordered a set of new bushings for my Mk 2 steering column. They were appropriately snug on the shaft but way too loose in the tube. As I have a lathe I machined myself a set out of Nylon with the right clearances. I suspect that the fix is to get them from another supplier who hopefully has a different source who makes them correctly.
I would be interested to know from whom you purchased the bushings to see if it was by chance the same supplier I ordered from.
George Jones
Private Restorer.66\' 3.8 Mark 2, 67\' Ser. 1 FHC \"E\"""
