the car runs hot, I checked all of the typical things and found that there was no flow on the right bank from the engine to the radiator. The left side is normal with hot coolant flowing well to the rad while the right side is hot up to the thermostat and cold to the rad, we switched the stats and it is the same. with everything open using a hose the flow seems to be the same. The radiator is new?
