All the gauges on my 67 2+2 are Smith's (which work fine) except for the voltmeter which is Lucas and (ahem) requires replacing. Recommendations and sources? I checked Moss, but they didn't look quite right.
Submitted by annette_close@… on Tue, 09/09/2008 - 12:37
Submitted by SE98-32482CJ on Sun, 09/07/2008 - 10:23
voltage meter
Earl mixing is common as Lucas was the electrical provider but the gauge was a visual match. You have a different issue though as your 1967 should have an amp gauge not a volt (or battery condition ) one--that came in in 1968.
Submitted by annette_close@… on Sun, 09/07/2008 - 08:42
voltage meter
Is it normal to mix makes of gauges? Should they all be the same?
Submitted by SC38-21185J on Fri, 09/05/2008 - 20:05
voltage meter
I would try to find a GOOD used one on EBay. When you get it, check it immediately and return it if it is defective. Don't buy if the seller won't refund money.
Failing that, you could send it to an instrument shop for an overhaul. I'd call Classic Instruments to see if they could take a look at it. Or they might have a referral:
http://www.classicinstruments.com/
Patrick
That helps. Thanks, Patrick and George. I appreciate folks minding this forum and being willing to assist.
