What engine number starts the better cam chain tensioners.
I have a 2000 XKR & I think most 2000 XKR's had the better engine tensioner.
Does any one know the actual engine number when the better tensioners were installed?
Submitted by stevejag@sbcgl… on Sun, 05/18/2014 - 11:54
Edited on 2014-05-18 11:59:53
That number cited by Phillip is an ENGINE number, rather than a VIN number. That engine is the first one to get the second design tensioner, but that second design only differed because a helper spring was added to the plunger to prevent a split-second rattle on startup. It was still the composite construction just like the original, and still susceptible to breakage at higher age & mileage.
Edit: That engine, by the way, would have ended up in a vehicle near the middle of the 1999 model year run.
The aluminum tensioners came later. I covered that a bit in another thread. The link is below.
As far as knowing what is in a given engine, the only certain way to know is to have documentation of the installation/replacement, or popping a cam cover off to have a look-see.
